Hello guys,
this one drives me crazy, I don't know why is so hard for Fusion to move / copy or mirror those lines, I tried multiple times, first with MIRROR function, it didn't work (fusion not responding, I had to force close it), than I tried using MOVE COPY command -> Create copy, rotated the objects perfectly, but when I hit OK, again it's not responding anymore ... and it's been more than 30 minutes since I try the **** rotation.
I know now it's easier to draw again the lines, but than why would fusion add a pattern feature if everytime I have to pattern many objects, it crashes, or I get warnings from fusion that I selected to many objects (or something like that, I remember a few months ago I seen such a warning, but not now).
Is it my computers fault ? (old i5, 16GB ram, GT 1030 video card)
Solved by LeonardoBN. Go to Solution.
Wow, that is a lot of profiles.
If you really want to mirror them, try disabling Show Profile in the Sketch Pallete. Do you need only the lines? If you check again Show Profile...you will have the same problem.
Thanks for the quick reply, but what's the trick with this SHOW PROFILE option, why does it work with it unchecked and it doesn't with it checked ? I just googled for SHOW PROFILE option, not much information ...Fusion360 Blackbox book
With that checkbox unchecked it worked instantly on my PC too, so it's not my PC fault ...
And a few minutes later, the diagonal engraving is done ... after so much struggle, because of a stupid checkbox, I'm curious now when I will need that checkbox again 🙂
@jeff_strater talked about this earlier:
Speed of Horizontal/Vertical vs. Parallel/Perpendicular constraints in sketch
