Fusion Drawing, how to get a "thru" hole in hole and thread notes.
Sean3073
Message 1 of 12
Sean3073
My question is, when doing a ASME drawing from a CAD model, and I have a couple of thru holes, how do I get the "hole and thread note" to actually say thru instead of the distance? I do realize I can edit the block and change it to thru, but it would be a lot faster if fusion just did it for me. Thank you guys for your time in advance.
Replies (11)
Message 2 of 12
hyperbolicindustries
@seth.madore Seems like a design question rather than manufacturing
Message 3 of 12
HughesTooling
When you create the hole you need to set the depth to all.
Mark Hughes
Owner, Hughes Tooling
Message 4 of 12
Sean3073
11.JPG222.JPGThats it! Thank you.
One follow on question though, when I model a tapped hole, (not selecting Modeled) it doesn't seem to work. It does work with all normal holes thu. Any ideas? Or is this an ANSI standard not to do that?
Message 5 of 12
HughesTooling
@ClintBrown3D  Any idea on this?
Thanks Mark
Mark Hughes
Message 6 of 12
ClintBrown3D
Hi @Sean3073 & @HughesTooling
What exactly is the question? Are you trying to add a hole note to a hole feature that has modelled threads, or is the thread manually created (i.e modelled with a helix)?
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
Message 7 of 12
Sean3073
It's a modeled hole using the hole command of which I have it as M3 x .5 for tapping. I did not have the modeled box checked. When doing the drawing and using the hole note command, it does not recognize "all" to generate a thru in the note box. But it will work if it's just a normal hole, ie not tapped. My goal / question is how do I use the hole command and have it recognize it as a thru hole and label it properly. And just for info, these holes are created using all in the "extents" section.
Message 8 of 12
HughesTooling
@ClintBrown3D  Picture should make it clear. Both holes where made with the hole tool, both set to All for the depth. The threaded hole doesn't have THRU in the note but the total thickness of the part.
Mark Hughes
Message 9 of 12
ClintBrown3D
Hi @HughesTooling &@Sean3073
This hole note designation is "as designed". The Thread depth is always specified.
My understanding, is that per the AMSE Y14.5 standard, specifying a thread depth as "thru" is not the preferred method.
You can always edit the note to  suit your requirement.
Hope that this helps.
Clint Brown
Message 10 of 12
HughesTooling
Is it the same for my example above? I have the thread depth set to 15mm but the hole is through.
Also does the note pickup its details from the thread XML file and if it does can it pickup the drill size instead of the minor diameter?
This is the info in the thread XML.
Thanks Mark
Mark Hughes
Message 11 of 12
ClintBrown3D
Hi @HughesTooling
I'll need to check with the team. I believe that the note pulls the details from the hole feature.
I'd love to meet up with you to discuss your thoughts around this. If you're up for it, here is a link to my calendar, please book a session with me, and we can go over this on Zoom.
Clint Brown
Message 12 of 12
Sean3073
I feel silly, I have been wondering that for years. Thank you for the tip!
