Fusion don't open SLDPRT files?
Message 1 of 9
I am trying to uplaod some very simple SLDPRT files I downloaded from GrabCAD to my project, but the upload always fail, even for tiny files with less than 200kb.
Is SLDPRT not supported at all?
Replies (8)
Message 2 of 9
Which path are you taking to upload your part?
Path 1. Open fusion and upload to A360
Path 2 . Open A360 and upload from there.
There is a path 3 where you work offline and then when you connect to the net work it up loads to A360. But I think that only works with parts from scratch.
Message 3 of 9
daniel_lyall
only some SLDPRT will open and it has to be the whole file other wise it will fail.
@Anonymous if you open the file I sent you with the Monte-Carlo and select all it will work if you miss some bit's it fails
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 4 of 9
Saw other threads complaining of SolidWorks 2016 not being supported yet...
Went to check in the GrabCAD (where I got the files from), and yep, SolidWorks 2016 😞
Message 5 of 9
So has that answered your question?
Message 6 of 9
Yes, but the solution was in other thread, so I can't click in a accept solution button...
Or rather, tehre was no solution. (I still need to open these files, it is just that there is no way to do it directly with Fusion right now)
Message 7 of 9
daniel_lyall
try from Your A360 account
Daniel Lyall
The Big Boss
Mach3 User
Message 8 of 9
zorka.ain
Is there any way to open a file of this type without using A360?
Message 9 of 9
TheCADWhisperer
You have replied to an ancient thread.
What problem are you experiencing opening a *.sldprt file?
Attach your file here for best advice.
