Fusion does not select the plane required
jaalpaca
jaalpaca
Hello everyone,
First of all, I don't know if this is the right board for my question. If it isn't please tell me or move it to the appropiate one.
I'm really new in this forum and with Fusion. I'm trying to import a svg file in order to extrude it afterwards, but when i try Fusion selects the "empty space" instead of the figure i want.
I know it's very difficult to understand what i'm saying. The attached image maybe explains it better. As you can see, the figure I want to extrude (the crown) can't be selected, but the empty space between it.
Sorry about my english, and thank you in advance.
TheCADWhisperer
Most likely you have a small gap somewhere.
File>Export and then Attach your *.f3d file here and end all doubt.
jaalpaca
Wow, thank you very much for your quick response! Attached is the f3d file, I thought the same but i can't find any gap.
davebYYPCU
Divide and Conquer,
 2 holes, under my circles/
Might help....
jaalpaca
That would definetly help. It's obvious i must still learn a lot,i didn´t find those gaps. I'll try that tomorrow and mark your answer as the solution. Thank you very much for your help.
jaalpaca
That was indeed the problem. Thank you very much again!
