Fusion frequently does not register my keyboard inputs until I click in the window. From what I can see, this only happens in the sketch environment, but it happens almost all of the time. I made the Screencast below for a different reason, but I will include it here as it illustrates the issue.
As you can see, when attempting to create a rectangle, I pushed "R" to create a rectangle and the keystroke was registered but Fusion did nothing until I clicked in the window. This also happened later in the video with the project command. This is strange to me, as Fusion already had focus. It also really slows me down, as I use the keyboard quite a bit.
I cannot show this in the Screencast, but this happens regardless of whether I am using Screencast or not.
Has anyone else noticed this?
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
Kudo button - If it resolves your issue, press Accept as Solution!
