Fusion - Combine feature not allowing tool body selection.
Hello!
I am trying to hollow out a model of a track spike shoe to resemble a cover that can be used on the bottom of my track spikes, protecting them from wear and tear across different surfaces.
To achieve this, I took a high-definition scan of my track spike shoe and imported the file to Meshmixer to make the model into a solid body as well as repair any cracks in the model capture. I also took the opportunity to simplify the model of my shoe so that functions in Fusion would run more smoothly on my school computers, which have proven to be susceptible to crashes.
I then imported the mesh model into Fusion as an object file and adjusted its positioning so that the model was in a desired working (i.e., editing) alignment. To help the school computers with function performance, I reduced the mesh model.
After converting the mesh model to a solid body, I defined a sketch plane tangent to one side of the model and sketched the shape of the cut I wanted to make to the top of the shoe model. After extruding the sketch and cutting the model, I achieved the shape I desired to make the “cover” for the underside of my track shoe. However, the model is solid, and needs to be hollowed out so that it can be worn on the bottom of my spike shoes.
My initial approach was to take my edited (i.e., cut) model of the shoe, copy the model, scale the copy down, and then combine the copied (scaled down) model and the original model to hollow the main body of the shoe. However, when I tried to use the combine feature, I was unable to select the inner scaled-down copy as a tool body to perform the cut.
Any advice would be helpful.
