Fusion: Circumscribed Polygon Radius and Sides Defined by User Parameters?
emmagolson
Observer Observer
emmagolson
Observer
Observer
this creates and inscribed polygon. is there a similar way to create a circumscribed polygon?
This post has been edited due to: @lauri_barnhart added the product to the title to help more community members find this topic.
skivvie
THIS. Been trying to figure this out for a while now.
HughesTooling
Here's a way to create a polygon using a feature pattern rather than a sketch pattern.
First create a base body to join the pattern to.
Then extrude the triangle set to join.
Now pattern the extrude feature.
If you edit the pattern and change the amount of flats it updates as a single body.
Hope this might give users an idea how to do this in other situations and pattern types. File's attached.
Also @emmagolson  sorry for late reply, this is an example of how to create a circumscribed polygon.
Mark Hughes
Owner, Hughes Tooling
jhackney1972
Another Forum user show me this method, I thought I would use you model, and parameters, to show it.  The secret is to create a Boundary Fill with the Join operation selected and then do a Feature Pattern of the Boundary Fill with the Compute Type set to Adjust.  If the bodies touch, it will join together automatically.  Thanks for the use of your model.
John Hackney, Retired
kacper.suchomski
From the process perspective, it doesn't matter whether the polygon is to be inscribed or circumscribed on a circle. It's just a matter of deciding and assigning the appropriate constraint (coincidence or tangency).
https://forums.autodesk.com/t5/fusion-design-validate-document/help-on-parametric-project/m-p/137585...
Kacper Suchomski
