Fusion - Bodies disappear from drawings after making an update to the model.
core_cmw
core_cmw
Community Visitor
Community Visitor
Many times, when I make an edit to a model in the Design Workspace, then refresh the Drawings, bodies disappear in the drawings. All dimensions lose their references. All bodies are still shown as visible in the drop-down tree. Hiding the bodies/components and then re-making them visible does nothing. Re saving the model and refreshing the drawings does nothing. For some reason they appear as visible when the drawing view is changed to shaded, BUT, only the faces, none of the lines are visible and you can't click on them for dimensions. My only solution is to delete the drawing view and replace it, but that waste a ton of time I basically have to re-do the drawings. This happened to me recently on a drawing with over 100 pages, that wasted countless hours
johnsonshiue
Hi! The behavior is definitely wrong. Before you redo the drawings, try clearing up the cached files locally. Then restart Fusion. Does it work better now?
Many thanks!
Software Test Engineer
