Hi
I thought I was doing quite well learning Fusion360 but I have come up against a complete brick wall!
I am trying to model a cctv camera housing. Hopefully you can see what I have done so far here: http://a360.co/2cwwLj6
What I am trying to do now is draw a 'bracket' that will attach the tube to the wall. In it's simplest form, this will be another 'box' like the current one on the side of the cylinder, with a flage on it to allow it to be screwed to the wall.
However, I want to model it as a separate component so as it can be exploded away from the cylinder.
I cannot for the life of me manage to draw a rectangle on the side of the cylinder, and then extrude it so as it matches the curve of the cylinder.
I have tried drawing a rectangle on a tangent plane to the cylinder, then extruding the shape into the cylinder and then trying to split it as a new body, but when I do that and convert it into a component all my joints break and the other components all start moving together!
Can anyone point me in the right direction? 🙂
Thanks in advance
