Fusion 360 Windows explorer crash for import AND export
ThomBD
ThomBD
every time I want to export or export a file via merge from windows explorer or save a drawing file in PDF, STL, cnc post processing, etc ... Fusion crash when opening explorer. Anyone have a solution please?
Thom
jeff_strater
that should have been fixed in the latest update to Fusion.  Can you check for an update and install it if there is one?
Jeff Strater
Engineering Director
ThomBD
i already check. i use it each day. but the last update dont fixed the bug. and try to uninstall and reinstall but it don't fixed it too...
exactly the same problem,
crash when i want to import a mesh...
I c'ant continue my work.
ThomBD
Try to close ALL apps except fusion and try again. sometimes it works for me.
