Fusion 360 sweep command
yogicoffey
Message 1 of 9
yogicoffey
using the sweep command to cut/extrude a lip around a edge
Replies (8)
Message 2 of 9
sachlene.singh
That is something you should be able to do with a sketch profile and a path. Let us know if you are running into issues.
-Sachlene
Message 3 of 9
jeff_strater
Here is a quick way to do this:
start with a body:
Then, create a workplane along path, along the outer (or inner, depending on the lip you are creating) edge:
This will result in a plane that is aligned with the outer lip:
Create a sketch on this plane, and add the geometry of your lip.  In my example, I want to remove some material, so a rectangle that overlaps the edge will do:
Then use Sweep, selecting your lip profile and the outer edge of your body as the path:
and OK will create your lip:
Hope this helps you get started.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 4 of 9
yogicoffey
Hi Jeff
Thanks for the answer.
Yogi
Message 5 of 9
thank you, and yes there is an issue :
when the Path of the sweep is not perfectly horizontal, then the Profile rotates causing a very undesirable lip groove. This might be some Sweep settings , but I tried all.
So , is there any idea how to make the Profile preserve its orientation ?
Thank you.
Message 6 of 9
TheCADWhisperer
A couple of offset surfaces should do the trick.
Or maybe an split and presspull (I didn't try this one).
Can you attach your *.f3d file here?
Is something like attached what you are after?  (I think I did wayyy too much work, but I am busy with other stuff to refine the solution.)
Message 7 of 9
Thanks for your time.
It just did the trick.
and I am attaching what i did learn from you.
thank you very much.
Message 8 of 9
constanza_el
Community Visitor
Community Visitor
your answer did not solve my doubt, but thanks anyways
Message 9 of 9
g-andresen
Please explain this using a concrete example so that hints for the solution can be developed.
It is best to start a new topic.
günther
