Fusion 360 modeling
Fusion 360 modeling
zakariadze1
Fusion 360 modeling
zakariadze1
I'm trying to press pull sketch and it goes down instead of going horizontal 5.PNGAnd it cuts like that not even whole body.
jeff_strater
Hi @zakariadze1,
If you could share your design here, you'll get lots of help.
But, a short answer to your immediate question is:  Extrude is defaulting to "Cut" because the profile intersects the existing body.  You can override that, however, by just choosing "Join" instead from the Extrude dialog:
Jeff
Jeff Strater
Engineering Director
jeff_strater
Sorry - post went twice - network hiccup.
Jeff Strater
zakariadze1
I want my sketch to extrude like you do but it goes like arch not straight 5.PNG
Yellow lines show how I want it to go and Blue lines show how it goes, as you see its like curvy
laughingcreek
You might be able to visualize the problem better if you extrude with a join.  That part of the cut droops down because your profile is sloped, and your cutting into  curved surface.  It's doing exactly what you are telling it to do.  Look at it normal to the plane, might be easer to visualize.
jeff_strater
Hi @zakariadze1,
Another approach you can use to get that straight line around your cylinder, you could use Revolve instead of Extrude:
Jeff
Jeff Strater
