Fusion 360 HOW TO Coil or helix with Stripes
soulrider911
Message 1 of 9
soulrider911
Hey folks I have ben struggling with how to achieve a coil that is striped not using textures but modeled. I have tried creating a coil, then another coil that was cut short > repeat on path... no worky.
I would like a coil that is striped. I have tried many things with no success. I would LOVE any help
Desired Outcome: Striped CoilDesired Outcome: Striped Coil
Replies (8)
Message 2 of 9
TheCADWhisperer
@soulrider911
Are you familiar with Split Face and Appearances (Face)?
Note the pattern on path.
Message 3 of 9
TheCADWhisperer
@soulrider911
Did you figure this out?
There is a real trick to the process.
Message 4 of 9
soulrider911
Thank you for the reply this is exactly what I am looking for! I actually don't have a Fusion file the photo I attached was just an image to articulate my challenge. Would you mind posting your file? I would love to see how you did it.
Message 5 of 9
TheCADWhisperer
@soulrider911
Questions like this come up often enough that I am creating a video of the process - but I always like to see that the user has made at least a modest attempt before I show the solution.
Message 6 of 9
soulrider911
I appreciate that I have attached my feeble attempt at this, though its not parametric / easily adjustable because i used the split body, circular pattern, and thus end up with a destructive method of creation if you will.
Message 7 of 9
soulrider911
Thank you I added a reply in the main post with an image of my attempt
Message 8 of 9
TheCADWhisperer
Message 9 of 9
heather_tracy
Hello, @soulrider911,
Did the information provided by @TheCADWhisperer help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Heather | Community Manager
