Fusion 360 EMBOSS help needed
tilakpatel531
tilakpatel531
Hi everyone!
I need to emobss this profile on the curved face that you can see in the middle. I know EMBOSS is the perfect feature to use for this. When I select the feature, I cannot select the curved face of the body. The face was created using LOFT command under SURFACES with the help of T-SPLINE curves and STITCHED later to make a solid body.
Now am I missing here something or did I do anything wrong?
Any help would be highly appreciated.
g-andresen
Embossing does not work on double-curved surfaces!
günther
tilakpatel531
I am trying to create something like this in the photo. How can I achieve it? Do you have any suggestions?Dxs1BtaXgAEcKwr.jpg
g-andresen
Try:
1.  SKETCH > Create > Project >Project to Surface
2.  SOLID > Modify > Split Face
Günther
