Fusion 360: Dependency of two ASSEMBLE/Joint - parameter and position of the Joints
boucher.claude
boucher.claude
Hello everyone
I have several related moving parts in my project and I would like to create a dependency for some of them.
The movement of a slider or an on/off switch triggering the rotation movement of the second piece.
The idea would be to "link" these two links to each other, or else to retrieve the displacement value of an object and apply this value as a parameter to an angle or to the displacement of a other object.
(just an idea : it could be great to get the value of a joint object in a parameter.
(view in My Videos)
jeff_strater
if it is a direct relationship between the two joints that can be expressed as an equation, Motion Link should work.
If you want more complex behavior, then Motion Link might not work.  But, from this video, it does look like Motion Link might work for you.
Jeff Strater
Engineering Director
boucher.claude
Thank a lot
It works fine.
