Fusion 360 deleting body
oystein.l.l
Message 1 of 8
oystein.l.l
hello! so im trying to delete a body on my fusion 360 but it seems to delete only faces what is the issue ? i have a video down below to show 🙂 im new to fusion 360 but i couldnt find any options to fix it.. so im here
Replies (7)
Message 2 of 8
jhackney1972
You know the drill, attach your model so the Forum users can give you a relative and quick answer.  You know how, or do I have to send your instructions again?  By the way, consider using Remove instead of Delete.
John Hackney, Retired
Message 3 of 8
oystein.l.l
thanks! again! also yes im a regular here now yes i attached file down below. i should have known this by now 🙂 yes thanks again for the tip remove, i learned this just, so if i use remove i dont delete sketchplanes right ? wich was my problem before thanks
Message 4 of 8
jhackney1972
As I mentioned, using Remove takes care of the body easily.  Model is attached.
By the way, if you are a regular, you should consider removing Linked Files from your assembly before posting so you post a F3D file instead of a F3Z file.  Forum users will respond quicker and it is a lot easier to attach and retrieve.  You can keep your original, just make a copy and unlink files.
Message 5 of 8
oystein.l.l
hey again somehow remove or delete doesent work i Linked a video wich shows the issue 🙂 its extruding my body when i press delete or remove any suggestions settings? I see you mean share public link very useful tip autodesk has alot of features! Its difficult to learn everything i started using it 5days ago 🙂
Message 6 of 8
jhackney1972
That plate is a part of a Rigid Group so maybe that is causing your issues.  You could also try to Remove the entire component since that body is the only one in it.  You used a MP4 to show your issue and not a Screencast.  Screencast, if you go back and look, record Fusion 360 commands so someone looking at it can tell what you are doing etc.
Message 7 of 8
oystein.l.l
I tried deleting suppressing rigidgroups it didnt work to delete body i also wanna delete body only because i wanna keep sketch, i cant copy sketch either… or i would just create a new sketch component
Message 8 of 8
oystein.l.l
I saved the files and restarted fusion 360, now i can delete body somehow… i guess this was a bug? I could not find the answear atleast, maybe you know?
hopefully someone with same issue finds this!
