Fusion 360 - Cutting angle on face
11 REPLIES 11
Message 1 of 12
pelseyHYPS2
1870 Views, 11 Replies
 hi. I am trying to face across the origin on this part that is mounted in a rotary. It’s a 12 deg angle from the flat down. It’s very much critical to quality that this angel is right. I can’t seem to get fusion 360 to track this correctly and all it wants to do it goofy moves anywhere. Does anyone have any ideas on what I can do to get this to program? I’m fairly new to fusion 360 but have 10 years machining on other software. It’s probably something simple.
Labels (1)
11 REPLIES 11
Message 2 of 12
sutherland-
in reply to: pelseyHYPS2
Hi @pelseyHYPS2
You could:
  • create a tangent plane by using the cylindric face
  • create a sketch on that plane
    1. use project function to project the cylindric face
    2. set the specifications of the angle and others (such as how far the cut is from the center and so on)
  • extrude the sketch.
  • mirror the feature
I attached the file so you can work with it step-by-step by going back in history marker:
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
Message 3 of 12
CNC
Message 4 of 12
Understood.
Best regards,
Level  sutherland-
Member
Message 5 of 12
Can’t see why that matters, the part still has to be modelled.
@pelseyHYPS2 You can cut the four faces with a std 3 axis mill and rotary chuck, or other indexing vee block.  What is it in your setup that is the problem?
Message 6 of 12
pelseyHYPS2
in reply to: davebYYPCU
I need to track that angled line on my part face and I can’t seem to do it
Message 7 of 12
pelseyHYPS2
in reply to: sutherland-
I got the side angles down. What I’m struggling with is the face that is angled 12 devs
Message 8 of 12
davebYYPCU
3 sketches each on the origin planes,
front circle, then side view for long cuts and top view for short cut.
Use sketch 2 and 3 for split body tool.
Might help....
Message 9 of 12
Warmingup1953
Is this a CAM question?
Message 10 of 12
davebYYPCU
in reply to: Warmingup1953
I think so, but without a fie, or knowing what setups are being created, dead end.
Message 11 of 12
Bunga777
It sounds like you are talking about machining with CAM.
I would like to know if it is Milling or Turning mill?
What specific machine do you want to machine on? It might be better if you tell me.
If possible, it might be better to attach the configuration file if it is ready.
Message 12 of 12
sutherland-
Following up on our DM's, here is the video of the reply above, as promised.
I used some key shortcuts during the video:
D = dimension (can assign any dimension)
L = sketch line
P = project
X = change between regular and construction line
I = measure
Please let me know if you need anything else
Best regards,
Level  sutherland-
Member
