Fully defined/white sketch is still draggable
programming2C78B
Advisor Advisor
programming2C78B
I also cant get the center slot fully constrained for some odd reason. Auto Constrain adds 0...
Please click "Accept Solution" if what I wrote solved your issue!
Christoph_360
Hello
I would capture only one Slot in the Sketcher, then extrude and then repeat with Pattern.
Christoph
jhackney1972
You are missing a defined distance from the construction line of the slot to another known point.  Model is attached.
John Hackney, Retired
