Fully constrained Not
etfrench
Mentor Mentor
Message 1 of 16
etfrench
This sketch claims to be fully constrained, but adding a line tangent to a constrained circle moves the constrained circle:
ETFrench
Replies (15)
Message 2 of 16
Thegreatrandino
Add a line from the center of one circle to the other
The relationship, or position of the circles and arcs on the right was not fixed or defined relative to any part of the sketch.
here is a screencasthttps://autode.sk/2vKGvoP
Message 3 of 16
Thegreatrandino
The relationship, or position of the circles and arcs on the LEFT (not right)
Message 4 of 16
g-andresen
there is no defined vertical distance between the centerpoints.
günther
Message 5 of 16
etfrench
@g-andresen , @Thegreatrandino : All of that is true, but Fusion 360 is claiming the sketch is fully constrained when in fact it is not.  Looks like a bug to me.
ETFrench
Message 6 of 16
jeff_strater
strange.  When I opened the file you shared here, it doesn't show fully constrained.  Interested in why you are seeing it differently:
Jeff Strater
Engineering Director
Message 7 of 16
Thegreatrandino
where does it say it is fully constrained. When I opened the model and look at the sketch, The left arc, the three left most circles and the upper line were all blue indicating they were not constrained.
Message 8 of 16
etfrench
The screencast shows the lock icon on the sketch before adding the line.  I can't say why it's doing that.
ETFrench
Message 9 of 16
Thegreatrandino
Wel well well.
I never notice that lock icon.
The model you uploaded is not constrained.
  • there are blue lines (the circles, arc and the skewed line on top)  and black lines
  • there is a pencil icon next to the name of the sketch beneath the sketch node in the browser
so how is a sketch which appears fully constrained  able to move?
I've looked at the screen cast and compared it with what I downloaded. Downloaded an fresh copy and still don't see it. Is the center of the circle on the  right coincident to the origin?
Message 10 of 16
etfrench
That is the question 😀
Yes, all of the circles on the right side are coincident with the component origin.
ETFrench
Message 11 of 16
Thegreatrandino
Post the model again please.
Why does yours on the screencast show fully constrained and the one posted does not?
Message 12 of 16
etfrench
Here you go.  I opened the exported file and it's showing the sketch as constrained.
ETFrench
Message 13 of 16
Thegreatrandino
Mine worked. Which is to say it worked as I expected: the sketch did not move.
I don't know why I can't duplicate what you demonstrated in the screencast.
https://autode.sk/2tnfTcF
Message 14 of 16
Thegreatrandino
HOLD THE PHONE
It appears it matters where the line is drawn.
Screencast to follow
Message 15 of 16
Thegreatrandino
I got different results went I the line in different places and selected different sketch object to be tangent
https://autode.sk/38TybkS
Message 16 of 16
Thegreatrandino
check out this screencast
https://autode.sk/2uexlQP
it appears the left half can move vertically
