Fully Constrained Issues
jdpreynolds
Message 1 of 9
jdpreynolds
Hello
I am trying to correct some issues with my drawing that are causing "downstream" problems with getting sketches to be fully defined.  I see that the "Hub" sketch is not fully defined even though the drawing is all black and reading through the forums see that this is an issue that others have had also.
I am trying to work out what I have missed to get this sketch "fully Defined" any help will be much appreciated.
Julian
Screenshot (10).pngHello
I have started to try and correct
Replies (8)
Message 2 of 9
etfrench
Use the Text Command, Sketch.ShowUnderConstrained, to find unconstrained geometry.
p.s. The first Sketch.ShowUnderConstrained with 3 points was from a different file.
ETFrench
Message 3 of 9
jdpreynolds
That's really great thank you
Message 4 of 9
TrippyLighting
If you keep the 7 small fillets out of the sketch you'd be surprised how quickly you will create stable fully defined sketches without problems. Keeping edges sharp as long as possible and applying them at the end of the timeline will also likely make lofting the spokes easier.
Message 5 of 9
jdpreynolds
Thanks Trippy that is very helpful I have made those changes
Message 6 of 9
jdpreynolds
Hi Ed/Peter
wonder if you could help me one more time,
I have gone through my sketches and now have them fully defined and just redoing the sketch "Spoke Profile 3/4"  For some reason I can't get the two circles to (R7/16 & R9/16) to turn black,  I have applied the coincident constraint to the vertical construction line and to the upper and lower "Vertical guide rails" and applied the Radius dimension.  Can you see what I have missed out?
Many thanks
Julian
Message 7 of 9
davebYYPCU
Click drag the circle, likely will slide up and down.  Hide the rails, and Coincident constrain the circle to the centre line end point.
Might help....
Message 8 of 9
g-andresen
What you need are the intersections with sketch "Vertical Guidelines", but not the projection of its 3D contour.
1. How it works:
2. quick coincident
günther
Message 9 of 9
jdpreynolds
oh that's brilliant and very informative.  Thanks for that Gunther.
