Fractions in dimensions?
When setting dimensions, is it possible to enter fractions or other simple math in dimensions? e.g. 3/16 rather than having to work out 0.1875, or 17/64 instead of 0.265625? I've played around but it doesn't seem so.
(I understand that with dimensions I can say something like d3+10 to make something 10 units bigger than d3.)
O.Tan
If I understand correctly, yes. You can have formulae in your dimensions.
Added tip: in parametric mode, you can create your own custom parameter, so when you draw, you can write the name of the parameter + your own added equation.
For example, let say rod "length" is 100 with diameter 20 and I know when the rod length is joined on both ends coincidentally, I'll have to add an additional +20 on each side, so since I have a parameter with the value 100, in my rod dimension I can key in "length"+40, so the actual total rod length will be 140 and in the future if I need to change the length, I just go to my user parameter and change the "length" value
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
TrippyLighting
Yes, you can. Also the formula will be kept intact after entering it.
for 3/16" youd actually have to type in 3"/16
herzinj
You guys have it right, using fractions is possible, as well as other simple math in equations ( +, -, /, etc).  You can also use them when creating equations with numbers and parameters.
James
https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png
This is fabulous — thank you all for your answers.
I tried this again, and it works as expected. I'm not sure what I was doing before. As a software engineer I'm shaking my head at myself.
O.Tan: Thanks for the parameter hint. I dug into the help and found the section on parameters. This is a godsend.
