Floating Point Overflow - "Failed to Boolean bodies together" - please help
simon.dyer
Message 1 of 11
simon.dyer
Surprizingly I cant find anyone else with this error message.
Simple enough operation, boolean cut of the shape of my GoPro from the fuselage of my plane design.
I got to this position by tweaking something earlier in the history, and a boolean that worked fine before will now not work.
Ive tried many ways to fix the geometry but cannot find anything wrong, except a couple of warnings where I converted projected shape into a sketch.
Im really stuck.  Any suggestions?  Cant share the file publicly.
Replies (10)
Message 2 of 11
simon.dyer
More info:
I isolated the probleem by splitting up my GoPro model, and the bolt hole subpart is guilty.  Not sure why yet, but I do see strange non symmetric constraints in the sketch that defines it.
Message 3 of 11
laughingcreek
what in that sketch are you referring to as strange?
Message 4 of 11
simon.dyer
When I extrude it, the result will not boolean with main body shape. Not sure if the restraints are a cause, or what it might be.
Message 5 of 11
simon.dyer
Okay Ive uploaded the problem.
I also redrew the sketch and extruded again and its all fixed.
But this is a workaround and not an ideal solution to a problem that arose after having worked when I changed something unrelated in the history.
Message 6 of 11
TrippyLighting
If you want help, you need to share your model.
Message 7 of 11
I'm getting this error as well while trying to do chamfers.
I've got a simple body which I've used the split face command to get some shapes on the face wich I've then used press pull to extrude. When trying to chamfer those I get the same error very random.
If I try with another line which works and then try with one that doesnt later it suddenly works out.
Message 8 of 11
TrippyLighting
@Anonymous Chamfer is really not the right tool do do this. You should use the draft tool.
Message 9 of 11
Draft didnt work either...fillet did work though, and I'm kind of in a pretty tight spot now so it have to do it for now...
Message 10 of 11
wilkhui
Update - I'm looking into the floating point overflow reported by @simon.dyer (ASM-5935 for reference).
Inderjeet Singh Wilkhu
Product Owner - ASM
Autodesk, Inc.
Message 11 of 11
HughesTooling
@Anonymous Have you tried the move\copy tool, select the face then use the rotate option.
Mark
Mark Hughes
Owner, Hughes Tooling
