Flipping text on path
karl
karl
Is it possible to  create two lines of text on the top and bottom of a circular path where both lines are right-side up, i.e. they're both right-reading (see below)?  As far as I can tell, I'd have to enter both lines in the same command, so I couldn't flip just one of them.  I'm also unable to select the circle the first line rides on to enter a separate second line on it.
jhackney1972
I believe the best way to do this is to use two arcs to place the text.  Model attached.
John Hackney, Retired
g-andresen
For a more precise positioning of the text, I would limit the path and then use the "Fit to path" option for the text.
günther
whittakerdw
Not to take credit away from these examples by no means, but one thing I do when creating wrapping text like this is I also use construction lines so its not hugging the bottom, or top, line then I hide/delete, the construction line. Just to give it a little space between the circles. You could also use the create an arc as was pointed out earlier and turn it into a construction line, which is what I did, but you could place it more towards the center to center up the text. These arcs are placed at 6.375" with a .394" text so its not centered.
karl
Perfect!  Thanks.
ipmcc
In my opinion, the inability to control which side of a path the text is drawn on is a pretty glaring absence. The effort involved in using two curves is tolerable when you have exactly two pieces of text, but when you have N pieces of text (and N > 5)? It's a complete nightmare. I'm tempted to do my text layout in Illustrator/Inkscape, convert the text to paths/outlines, and then import it as a DXF or something like that. I've been fighting with this for too long. We already have horizontal and vertical flip controls, why not a "side of path" flip control. Seems like a pretty bad oversight. Oh well.
-Ian
