Hi! Each time I use variable fillet command I get no idea how does it detects the start and end points. I mean when I start selecting edges one by one I put in the values for the the start and the end and I see that the start point goes from the top and the end point lies in the very bottom of the edge and that’s ok. But when I’m continuing selecting another edges I see that the values I put in to the start now refers vice versa, that means that if for the first edge I had to put for example 1mm fillet as the start value and for the bottom 0,2mm now I have to do it vice versa because of F360 detects the start from the bottom of the def and the end from the top. This is not a big problem of course as long as I can visually determine that I need to flip start and end values but maybe there is some workaround that’ll help with that. Thanks! P.S. please, delete same my question from the support thread where I’ve posted it right now, didn’t find an option to remove it by myself.
