Flip dimension, how??
Message 1 of 23
Hello community!  I am wondering if there is a way to flip sides of the leader.  I have started making drawings and it sure would be nice to be able to.  please see attached image.
I would like to make the underlined dimension be placed in the empty circle.
Replies (22)
Message 2 of 23
PhilProcarioJr
@Anonymous
As far as I have found you can't. The only time I have found it to flip is if you place it under the area being measured and not above it.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 3 of 23
Bummer..  Thanks Phil.  I just tested what you had mentioned and it does flip but it is not where I desire the dimension.  I guess I will suggest this to ideas.
Thanks again
Message 4 of 23
Here is a link to vote for the idea if you would like to vote for it.  🙂
dimension leader flip
Message 5 of 23
PhilProcarioJr
Phil Procario Jr.
Message 6 of 23
brysonwhitedesign
Any idea when this bug (found four years ago) will be fixed?
Message 7 of 23
rushabhthakkar_910
If I am not wrong, this what you were looking for..? And I assume that this has been fixed now... @brysonwhitedesign
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 8 of 23
brysonwhitedesign
I’m not sure what you are referring to. What is the fix to the original post?
Message 9 of 23
rushabhthakkar_910
I  think Leader note is what is being discussed here...?? And Leader Notes are working good for me...
Thanks and Regards,
Rushabh Thakkar.
Message 10 of 23
brysonwhitedesign
No. It’s not notes that are being discussed here. It’s dimensions. See the original post.
Message 11 of 23
rushabhthakkar_910
Has the option of Leader taken away from Fusion...? Because I am not able to see it... So maybe I misunderstood it with Leader Notes... See the Attached Image...
Thanks and Regards,
Rushabh Thakkar.
Message 12 of 23
rushabhthakkar_910
@brysonwhitedesign , I think I was able to flip the Dimension... After some research, this is the result...
Thanks and Regards,
Rushabh Thakkar.
Message 13 of 23
TheCADWhisperer
I don't think that you understand the problem description.
Rather than make up a different problem - can you solve the original problem? (And post the actual file here.)
Message 14 of 23
rushabhthakkar_910
Sure @TheCADWhisperer , I would like to but where is the Original File...?? Or I should try it with some other file, and than post it here...?
Thanks and Regards,
Rushabh Thakkar.
Message 15 of 23
TheCADWhisperer
I simply used the original image to create a representative geometry to illustrate the issue.
Message 16 of 23
rushabhthakkar_910
That's Great.. And sir, can you share the file here..
And again so that I do not go into the wrong issue, can you confirm that the issue is related to Leaders... And that they are not coming towards the left side... ?
Thanks and Regards,
Rushabh Thakkar.
Message 17 of 23
brysonwhitedesign
Yes, it has to do with leaders, but not just any leader. It's not talking about a note leader. It is specifically talking about a bent dimension leader. This was shown in the image in the original post as well as a followup post. See the attached images. The need is to be able to locate the dimension on either side of a bent leader. Or, in other words, point the bent leader in either direction.
Message 18 of 23
rushabhthakkar_910
@brysonwhitedesign and @TheCADWhisperer , as far as I know, there is no Command called Leader or Bent Dimension Leader. The command that exist is Leader Note as far as I know.
If I am wrong, can anyone make a Screencast video showing an example of where it is used... Any model will work ... Not necessary that the original model should be there...
Thanks and Regards,
Rushabh Thakkar.
Message 19 of 23
TheCADWhisperer
@rushabhthakkar_910
If I am wrong...
The command is Dimension (d).
Message 20 of 23
a.griep
And here we are, almost 8 years later, and is there any progress???
What are we paying Autodesk so much for if they can't deliver such a simple function?
Complex 2ds get cluttered and hard to decipher without this function.
