Message 1 of 8
I would like to plasma cut the red pipe so that it sits on the red tube. I need to project the outer surface of the red tube on a flat plane, so that I can use it as X-Y coordinates to run the plasma cutter (to be built, so far I have made this CNC router: http://www.ingdemurtas.it/automazione/cnc/ ), or print it on paper to wrap around the tube as a template.
The drawing below was made in the modeling workspace. I read here that F360 can flattern only sheet metal, but how do I create a tube in the sheetmetal workspace?
