Flatten a variable simple curved surface
metcalfm72Z88
metcalfm72Z88
I am new to Fusion 360. How do I flatten these surfaces to create flat patterns for cutting.  They were created by offsetting from a solid.  They are simple curved surfaces that can be cut out of a piece of paper. Outside of exporting to Pepakura or Meshmixer (unwrap) any suggestions?
https://forums.autodesk.com/t5/user/viewprofilepage/user-id/2969125
https://forums.autodesk.com/t5/user/viewprofilepage/user-id/587929
hamid.sh.
If they are developable surfaces you can convert them to Sheet Metal (Sheet Metal > Create > Convert to Sheet Metal) and then use Create > Create Flat Pattern.
If possible share your file (or just surfaces) here so others can help.
Hamid
