Flange between two edges?
RayvenMaker
RayvenMaker
Is there a way to create a flange that connects two selected edges? Something like the "Bend" tool in Inventor. Thanks!
@RayvenMaker
promm
@RayvenMaker,
I am taking your question as the ability to "join" two base flanges.  Where you would create two closed profile sketches, next using flange make each as a separate flange and then connect them.  When we release August 8th we will not have this functionality.  Right now you can join a "contour" style flange to a "base" flange (I am using quotes because we only have one flange button).  The workflow you have requested is in our backlog, there are some higher priority features we will complete first.
Cheers,
Mike
RayvenMaker
@promm
That's right. Could you use a contour flange and a sketch to connect the two to work around not having that feature? Thanks!
@RayvenMaker
promm
Unfortunately, it will only combine with one of the edges.
Mike
