Have to redefine a saved parameter in order to change the Units. However, I know there are no uses of that variable any longer - I deleted the one use, but I'm getting an error "cannot delete ... used in d###."
Unfortunately, as "d" numbers are global (to design), and not sketch specific, I cannot find it - I know the original dimension using the parameter is d123, which I'd changed to reference the new, correctly defined Unit, variable. There are only 2 dimension used in that sketch (d123 & d124), but ... I tried deleting the dimension referenced (d123 - unresolving the sketch), but I still get the error.
Checking teh other two sketches, none of theirs are in the d12* range at all.
How do I find the "d" location where that variable is used so I can reference the new parameter, and delete the invalid one?
Thank you
