Preamble: In Fusion, the bulk of my assemblies are made with components linked into the assembly. I tend to reuse components and find this method yields the best results for my designs and workflows. I generally create subfolders within a project to organize the various types of components (e.g. discretes, mechanical, power, archived parts, temporary assemblies, etc) so I are usually end up with a number of sub-folders in a given project.
Question: I was working in an assembly with a number of components linked in from various sub-folders. I wanted to take one of those linked components used in the assembly and link it into a new assembly, but I wasn't sure in which subfolder that component was stored; getting properties on the component did not give me its path. So I opened the linked component from within the assembly, however, even with the component file open could not figure out which subfolder in the project I had stored it.
I was on a flight and in offline mode, so search is disabled. However, upon my arrival, I reconnected, and searched, but the results still only give me the component, not its location. I tried looking at the tabs to see if they had the file path, tried looking at the "properties" of the component itself, all to no avail.
I eventually found it by manually going through each subfolder in the project, but I am hoping someone can tell me a better way to find the storage location of a component - ideally from data within the file itself, e.g. some "get info" function - or equivalent - that I am missing.
Anyone got an idea on this?
