Finding dimension on tapered component
Amateur with a very basic question.  I would like to create a line, circle, etc along this tapered component at the point where the taper becomes 51mm in diameter, and I'm not sure how.  The reason why is so that I can add a dimension along the z-axis to that point in a drawing.
TheCADWhisperer
Dimension.
Where is your history?
jhackney1972
I did a Screencast of my method.  Not sure if it is the best one but it gets the job done.
John Hackney, Retired
Thank you, that was very helpful!
