Finding center between two sketch points
Cowski
Cowski
Hopefully this is easy enough.  I did do some digging through the forums here and didn't find exactly what I was looking for.  Hopefully my screenshot below will be enough to ask my question.
laughingcreek
draw a line between the 2 points (I'd also convert it to a construction line).  then place a "point" (from the sketch menu) on the line at the midpoint.  when you hover over the line with the point tool selected, a triangle shaped constraint will appear when you are close to the midpoint, that's where you put the point.  If you need I'll screen cast it for you
Cowski
I totally missed the "line" feature in the sketch menu.  Once I did that I knew exactly what was coming next.  I'm rather embarrassed and sincerely appreciate the time you took to answer this question.
Thank you again very much...especially the offer to make a screencast.
