I know there is ongoing discussion into sheetmetal with fusion so in the short term i have used the following workaround to generate folded sheet metal parts for my project.
Now this isnt to much of an issue in the sketch as laser cutting is 2D not 3D but when rendering my solution leaves a gap that i would really like to fill.
My workaround is to extrude the part then split it into bodies and then components but this leaves a section where the material would be stretched in real life missing. So is there an easy way to fill the missing section as seen in the picture below.
I have included the archive file if some one wants to try
Many thanks
Graeme
