Filleting problems
Filleting problems
chris.obrien.07
Filleting problems
chris.obrien.07
I have two versions of a guitar body in fusion
V1: sketched the outline with arcs and curves making sure all lines joined with tangents
      this body fillets perfectly for an 8mm fillet
V2 the sketchoutline is a spline and two straight lines
    this body will not fillet beyond 3mm
From my research I thought that once all lines to be filleted were tangents to each other.. all would be ok.
see screenshot attached
can anyone help me why the body extruded from a spline will not fillet beyond 3mm and how to fix it?
thanks
Chris
laughingcreek
when a curve IS tangent, but not selected, it can also cause fillet to fail.  what happens if you delete the indicated fillet?
I have noticed this also.  I just select them one at a time and do them if it doesnt "all select"
The real bugger is the reverse ie when you want to delete the fillet, sometimes it is impossible.
So my point / tip is do fillets and chamfers as the very last thing in case you want to back out.
