Sure, why not. 4th times a charm. lol What should the proper work flow be? I got it to work by sketching on the bottom, extruding .05" to cut to remove the lateral lines that I have no idea the origin of and then combine extruding that surface up .05" to create a smooth bottom and then remove the .05" surfaces created on the perimeter and then fillet worked fine. I then removed faces on the top to get it to only 4 surfaces and then fillet worked there.
I'm sure this is akin to building a car to get across the street. I've only been on this project about 15 hours. How long should it take someone competent? Just curious.
Here's where I'm at now which is as close as it needs to be for this but I'd love to know how to make the model exact to the mesh in less than a lifetime or so.
I am quite computer illiterate but I'm assuming all those squiggly lines means something bad.
