Fillet problem
Fillet problem
fahraynk
Observer Observer
Fillet problem
fahraynk
Observer
Observer
So Fusion wont let me fillet this edge alone.
I make a circle 84mm, extrude it out 50mm. Then I put another circle 18mm and revolve/cut.
The problem that is driving me nuts is... I want to extrude only the center circle. Every time I try, no matter what I do... if I fillet the center the adjacent edge also gets a fillet. How can I fillet the center alone?
jeff_strater
Oh, wow.  That is a good find, @fahraynk!  That is definitely a bug, and a pretty bad one.  I will file that and get a fix going.
As a workaround, I would add the fillet in the sketch before you do the revolve.
I apologize for this bug.  That one should not have gotten through.
Jeff
Jeff Strater
Engineering Director
I_Forge_KC
@jeff_strater Chamfer is affected as well.
Rule fillet is not though!
K. Cornett
Generative Design Consultant / Trainer
