Fillet on Patch
Fillet on Patch
Fillet on Patch
I have sketched a l-shaped line, then a patch with extrude.  I'm having a problem creating fillets on all four corners.  Any help would be appreciated. Thanks Paul
PhilProcarioJr
Can you post a screen shot of the surface and the problem area?
Are you sure it's a patch and not a solid?
If it is a patch did you stitch it all together before trying to fillet it?
Phil Procario Jr.
Owner, Laser & CNC Creations
Yes I did stitch it first.
HughesTooling
I think you'll have to make a sketch with an arc and use Split Face, I tried this and it is quite fiddly. It would be easier to make the patch from an outline to start with, like this.
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Another option is draw a sketch like this
Then use extrude cut.
Mark
Mark Hughes
HI,
I can create fillet on rectangle with no problem, when I created the L shaped flat plane than I can not use fillet.
I have created rectangle and split into two sections and would like to rotate one of sections 90 degrees
