Fill in extruded outline
1 REPLY 1
denisschneider
98 Views, 1 Reply
This is 100% a easy solve for most of the people here, but I can't figure out how to do it.
I want to fill in this outline to make a holder for my speaker. What I can't figure out is how to fill in this object so that it is a solid that I can 3D Print it.
Tags (3)
1 REPLY 1
My advice would be to do some of the some of the self paced learning to get the basics because you're making very basic errors.
You have used a surface extrude rather than a solid extrude. You also have several redundant sketches and forms in the timeline.
And the biggest problem is you need to create the profile in one sketch not 2 like you have.
With all the details in one sketch you get a closed profile you can extrude as a solid.
This is with a single sketch, see attached file.
Mark Hughes
Owner, Hughes Tooling
