Fill holes on curved surface
avispa4291
avispa4291
I have a model with a few holes that go through a curved surface that I want to get rid of. The file is f3d but I don't think there is a timeline or at least I don't know how to check. I have tried to delete the hole but that is not an option. Is there anyway to fill the hole to contour to the surface? attached is pic
Warmingup1953
Can you share your Fusion file?
avispa4291
so I was able to fill the two forward holes by extruding and then using split body to cut off the ends that extended but the rear hole is on the rounded and curved surface and it wont let me use split body using that surface. I know this is probably not the proper method but I am just a hobbyist at best
g-andresen
suppress feature!
günther
Warmingup1953
avispa4291
ok this is a stupid question but how can you see the timeline?
Whelp I'm an idiot, I was inserting the design and not opening it so it wasn't adding the timeline info, thanks for the help
