Files wont open
Files wont open
Files wont open
I can´t open the file bellow on both ways, using Fusion app or at A360
https://myhub.autodesk360.com/ue2961ff0/g/projects/2016010622597731/data/dXJuOmFkc2sud2lwcHJvZDpmcy5...
NicolasXu
Hi oziz10,
Thanks for reaching out to us. I was not able to access the design due to lack of the permission. Could you either invite me into the project or share the public link of the design, so we can take a close look at it? My email address is: lixiong.xu[AT]autodesk.com
You can also PM me the link if you prefer.
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Hi Nicolas,
This is not the first time to happen ...
The link is bellow
http://a360.co/1Q5Px2R
NicolasXu
Hi oziz10,
Thanks for sharing the design. I will follow up and let you know the result.
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
NicolasXu
Hi oziz10,
We did some initial investigation on the problem. There are several links (external references) in the design may be broken. It looks similar to a problem mentioned in this thread:
http://forums.autodesk.com/t5/design-validate-document/if-you-were-offline-during-the-fusion-360-mai...
Could you take a look at the thread and check if it’s the case (“were working offline during May 7 update” & “opened the file on a different computer”)?
If it doesn’t work for you, could you provide a copy of the diagnostic log files after trying to open the file again (so we can see the exact error in the log)? Or if you prefer, you may invite me into the project and we can do more investigation and try to fix the file.
Sorry for the inconvenience and thanks for your patience.
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
