Files rebuilding wrong on load?
i-make-robots
i-make-robots
Two of the many parts in my design rebuild wrong every time I load the file.  F360 seems to change the sketch areas selected for extruding, which trickles down through the rest of the design.
I can go back in the timeline and repair the mistake, save, close, reopen, and the problem has returned.
My solution has been to redesign the underlying sketch.  I don't yet know if it will work.  In any case...it's not expected behavior, right?
Is this a known issue?
i-make-robots
The file is here: http://a360.co/2pgpNaG
The "anchor" component also has a similar problem: on load a fillet is angry because an earlier extrusion is broken.
jeff_strater
Hi @i-make-robots,
I am looking into this issue.  I'm not 100% certain, though, that I am looking in the correct area.  Can you review the video below and let me know if I am looking at the correct feature?  It seems to work OK for me after opening the design, but perhaps I am looking in the wrong place:
I don't at all doubt that you are seeing these results, I saw the screenshots.  Just trying to reproduce them in my environment.
Jeff
Jeff Strater
Engineering Director
