File path while in "Offline Mode"
When in "Offline Mode" you can load your designs (files) from the "Data Panel".
What is the file path to those files, (where are they stored)?
Thanks in advance
innovatenate
Autodesk Support
Autodesk Support
I think the below link will help you to locate your locally cached files.
http://knowledge.autodesk.com/article/How-to-locate-locally-cached-files-in-Autodesk-Fusion-360
I hope that helps!
Nathan Chandler
Principal Specialist
Thank you
