Feature selection
Feature selection
PaulMunford
Autodesk Autodesk
Feature selection
PaulMunford
How do we select a feature that is underneath another feature?
In Inventor you can pause - and then pick. Or right click and 'choose other'...
Paul
Paul Munford
Technical Onboarding Architect
Linkedin
philip.s
Hi Paul, it's actually just the opposite.
Hold down the left mouse button on the interesting geometry and a list will appear, allowing you to select a different feature. Hope that helps!
PaulMunford
Thankd Phillip 😄
Paul Munford
Linkedin
myra1947
Community Visitor
Community Visitor
hi...i am trying to select a feature in push pull.  I want the diameter and it gives me only the material thickness.  I tried holding the left mouse and every choice gives me thickness.
hope you can help.  thanks
Myra stewart
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here?
(Or at least a screen capture image?)
