Reading through the last 5 pages of replies, just thought I would throw my 2 cents in as well.
Printer support? Why do I have to export as a .pdf and then open it up to print it out? It's super fun when I make a couple rev changes and have to repeat the process.
Associativity from model to print? Testing it out, the features would update on the print, but dimensions were static. I changed a hole from 30mm to 20mm, the hole physically changes, but it was still dimensioned as a 30mm hole. Re-dimensioning it yielded a 20mm dimension.
Lack of specific dimensioning tools and line types. I'd like to draw a circle on a bolt hole pattern to display that they are in fact located on a common axis. No option for center marks for holes/circles? What about construction lines to properly indicate angles between 2 holes?
What about print templates? Quite often I will see myself inputting the Same. Stuff. Over. And. Over.
The title block info: Is it really necessary to have to click/drag to add info? Any thoughts on making it more like a Windows Excel Field interaction so you would just click on the box that is there, type what you need and be done? Maybe when you click on a field, a bar would pop up with simple formatting options, like font size/style/color and justification left/right/center etc.
Also in regards to the title block, a little customization would be nice, such as adding or redacting fields. I'd want to occasionaly add something in regards to Mat'l, Coating, Rc, Edge Breaks, Fillets, what have you. Individual needs will vary depending on shop needs, which is why I advocate some custom modifications ability
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
