Feature Request: Keyboard Shortcut to Jump Between Required Selections in Operations
officeZJ276
officeZJ276
Hello Autodesk Fusion Team,
I would like to suggest a small UX improvement that could significantly speed up workflows across many operations.
During commands such as Sweep, the workflow typically starts with:
  • “Select Profile” → user selects profile
  • Then “Select Path” → user must manually click the next “Select” button before choosing the path
It would greatly improve efficiency if there were a keyboard shortcut to jump between required selection fields within an active command.
For example:
  • Tab → jump to next required selection
  • Shift + Tab → jump to previous required selection
This would:
  • Reduce unnecessary mouse movement
  • Speed up repetitive workflows
  • Improve accessibility and keyboard-driven modeling
  • Create a more fluid command experience
This concept could be consistently applied across all multi-step operations (Sweep, Loft, Revolve, Combine, etc.), making Fusion feel even more streamlined and professional.
Small UX refinements like this compound over thousands of hours of usage.
If you implement it, I’ll gladly accept the hourly rate of your senior UX/UI designers multiplied by my 1000+ hours in Fusion as compensation for the idea. 😉
Thanks for considering it!
SaeedHamza
After years of using Fusion, I totally agree on how annoying it is to go back and forth to the dialog box to hit the next selection!
Saeed Hamza
nexaner7
Observer
Observer
I am still looking for a solution as well. I am using an ultrawide display so it takes extra long.
officeZJ276
Uff, I cannot even imagine how much longer it takes you to finish one simple operation.
The time spent and the extra mouse clicks over the years...
navarro_matt
Observer
Observer
For the love of god please do this
