FEATURE REQUEST: Adding Volume to physical Properties
When adding a note in the drawing workspace. I would like to have the option to assign the 'Volume' property to the note. Now you only see 'Mass' as an option.
Oh and why is 'Dimension Units' linked to the 'Volume Units'? For example when you switch from 'mm' to 'm' the properties panel switches the volume units from 'g' to 'kg'. In many cases I want to see the 'mm' as dimension units and 'kg' as volume.
I hope this will be possible in a future update!
