Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
FEA Test of Inner Bracket
3 REPLIES 3
547 Views, 3 Replies
Hi
I'm trying to conduct an FEA simulation test to see if the inner bracket is able to withstand a 50kg load placed on top. The inner bracket holds two pieces of aluminium rails together. How do I go about constraining, applying the load and contacts for this study?
3 REPLIES 3
sanket223.patil
Hello @Anonymous
Can you Share the model here . So I can show you how to Conduct FEA analysis .
Sanket Patil
Mechanical Engineering
Expert Elite
in reply to: sanket223.patil
Hi @sanket223.patil
Attached is the file. I'm trying to test if the bracket is able to withstand a load of 50kg acting vertically downwards on the horizontal rail. However, I'm not too sure which faces on the vertical rail to constraint, which moment/loads to apply and how to apply the manual contacts. Looking forward to your reply.
Melissa
shigeaki.k
Hello @Anonymous,
I don't think the file was attached with your last posting. Also, would some of the examples and documentation in the Fusion 360 Help "here" assist with your issue at hand.
Shigeaki K.
Shigeaki K.
Technical Support Specialist
サポートとラーニング | Support & Learning
