I want to save the interference as a body.
I have used this simple example to show how the 'keep' check box is missing from my designs
Am I missing something, as Im sure I was able to do this before when I tried. ?
Thank you...
Thank you...
Solved by mavigogun. Go to Solution.
I reckon the tool you want is Combine, found on the Modify menu, which includes an option to retain the Intersected portion of Bodies.
Here we see the Intersect in blue between a Cube and a Sphere.
