F360 beginner questions
1) How do I change an offset? Created as 1mm, want to make it 2mm
2) Press/Pull does not update underlying sketch. Sketch changes update forward into the 3d model, do changes to the 3d model propagate backward into the sketch?
3) I have a 2mm base plate with a circle, offset and press/pull to make a tube through the plate. How do I create a fillet at the junction of the
pipe and the flat plate? There is no edge to grab and fillet.
4) I want to create a lid for the pipe I just created. Is there a constraint that will force the lid to track the pipe diameter?
5) Delete does not seem to work for me. I can't delete bodies.
6) Watching one of the introductory videos, the speaker writes these squiggles on the screen - it seems to activate the items on the popup menu for move/copy/delete/etc? Whats up with this?
Joe
PS: Is there someone at Autodesk who'll answer questions over the phone for $$?
