Extruding a sketch the distance between two points/faces on separate components
richard_sim
richard_sim
I'm creating a cartesian X/Y gantry system parametricaly, with the dimensions of the model all stemming from a few basic dimensions of the linear rails and extrusions. I'm trying to create an extrusion for a cross-bar between two uprights (each are separate components, all with joints keeping them in place relative to the parametrically driven parts), and I want its length/extrusion distance to be the distance between the uprights. I'm not sure how to approach this however, as I don't think I can just dimension a sketch (while keeping everything up-to-date as the parameters change) like I would if this was all a single Component. There's no way I can easily calculate an expression for the distance, as it's based on the offsets and sizes of various brackets, rails, etc relative to the parameters I do specify.
TrippyLighting
What exactly is the question ?
richard_sim
Sorry that my question wasn't terribly clear - the problem is that I don't know what the solution is of course, and that's making it hard to phrase the question directly.
What I'd ideally like to be able to do is create a dimension between two locations on separate Body's (which are also in diffent Components), and then use that dimension to drive the Distance of an Extrusion (which is on a Sketch in yet another Component). I'm pretty sure that's not possible, so I'm looking for an alternate way to achieve that same effect.
HughesTooling
The only way you could do that at the moment would be if you used a joint between the 2 components then used the offset parameter to drive the sketch. Like this where there's a rigid joint between the 2 part with on offset of 50mm(d22)
Mark
Mark Hughes
Owner, Hughes Tooling
